What type (part #) of HONEYWELL zone valve do I have? They are 25 years old.
mpmn04
mpmn04 Member Posts: 3
  • yellowdog
    yellowdog Member Posts: 290
    Look like standard V8043 zone valves.
  • Big Ed_4
    Big Ed_4 Member Posts: 3,422
    edited January 2025
    The valve has a inverted flair pipe connection . Normally you would fine them on baseboard mounted locations as in apartment buildings . I replaced a few … Erie, Flair ??
    I don't see the need for removing the valve body with Honeywells , the powerhead , motor and valve workings are replaceable …
  • mpmn04
    edited January 2025
    Thank you for replying.
    Is this the valve I would need?
  • Big Ed_4
    What is the problem or issue ?
  • mpmn04
    edited January 2025
    Big Ed_4
    The zone valve motor quit. I replaced it with a used motor I had laying around and got it working again. I have 3 more valves in use that are just as old, so I want to be prepared for when they fail.
  • Big Ed_4
    Stocking a replacement powerhead would be a good idea, covers you for a bad end switch , gearing and motor …
