Air to water heat pump system design
To put the BOM in perspective:
Chiltrix has a price list on their website. I'm not advocating that particular brand, just that it's easy to look up pricing. And I don't feel I'm giving away any trade secrets, it's right there on the Internet. It's at:
To do DHW, you need at a minimum an indirect tank and two 3-way valves. The 75 gallon indirect tank is $2299, the 93 gallon one is $3680. Three-way valves are $182 or $199 each, depending on which model of heat pump you have. So you're looking at a minimum of $2663 and possibly over $4000 just for parts. If the water tank is more than 30 feet from the heat pump you need a booster pump, which is another $329.
For your money you get a system that is more complicated, doesn't deliver any more hot water, doesn't cost any less to operate, and doesn't take up any less space in the mechanical room.
"R290 refrigerant, for those who haven't read the data sheet, is just a very highly refined propane. It is a good refrigerant — it has some very desirable properties from that standpoint. Unhappily, it also happens to be highly flammable as well. In fact, a somewhat cheaper and less refined version is sold as "LP gas" as a fuel. It forms explosive mixtures with air over a remarkably wide range of concentrations.
A minor detail, perhaps."
Jamie, thats why they call it propain, cause its gonna hurt when it blows up. Lol
I got Jamie to send me his cost of oil and electricity in a PM. It's $3.50 and $0.31, which makes his break-even COP 2.85.
There's no getting around it, oil is cheaper, there's no economic sense in going to a heat pump.
So what's going to happen in coming years as we decarbonize our energy mix? I expect that electricity will get cheaper and oil will get more expensive, so the calculus may change. But as a steam heating plant in an historic house, it would be a tough conversion. More likely it will shift to a carbon-neutral form of oil, either plant-based or synthetic made using captured CO2 as the feedstock and off-peak electricity for power.
That's probably what will happen with aviation fuel as well.
1
