Leaky UticaBoiler
jgreend40
Member Posts: 2
Residential Utica Steam Boiler is leaking and put the fire out on thermal coupling, is this a dyi
Is this a DIY project?
No. Unfortunately you most likely need a new boiler. Unless it is a pipe fitting on top that is leaking behind the jacket but it's more likely a leaking boiler.
Post more information before you jump into anything. A lot of contractors do NOT do the right job. Don't get caught with a bad contractor as so many others coming to this site have.
Post your location we may know someone who can help.
DYI: Do_Yourself_In.
