Arco AC 101B Steam
keith123
keith123 Member Posts: 105
would anyone having any sizing charts for these? Apparently there were two models. A 101B and a 201B.
I’m looking for the connected EDR ratings
    mattmia2 Member Posts: 16,670
    There's a steam coil in there? Is there also a blower in there? The output is going to be dependent on the coil and the airflow.(and the return temp). there is probably a chart in the old arco catalogs. i think there are some arco catalogs in the library here.
    keith123
  • keith123
    I did a search on this site already.
    The most I was able to find was in a 1938 catalog found on an archive website.
    Thank you though
    EBEBRATT-Ed Member Posts: 20,144
    Start it up and take the air temp in and out. Then measure the cfm air flow. Get the BTUs you calculate and divide it by 240 for EDR or divide it by 1000 to give you LBs of steam.
    Easy calculation when you collect the measurements.
    keith123mattmia2
