Boiler oil burner dripping oil
A small drip of oil (it's red) is coming from the oil burner of my boiler. It looks like it's coming from the black plug on the underside, where I indicated with the arrow. What would cause this? Our annual servicing is in 3 months. Is this more urgent than that?
I know nothing about boilers, so want to learn something about the issue before talking to a tech. Thanks!
I don’t see any stains on the floor.
Thank you Ed!
Pecmsg, It's just out of frame on the bottom of the 1st photo. The white thing at bottom of the photo is an absorbent mat, sitting in a pan, on the floor. I have that catching the drip.
I haven't called for service yet, I was hoping to get some ideas of what might be happening beforehand and if it was possible to repair/troubleshoot vs having to replacing the whole burner. Having a boiler is new to me, I'll look up the possibilities you mentioned. Thank you!
No one is saying you need a new burner or boiler. There is only a few things it could be.
Leaking pump seal
mis adjusted or dirty burner
damaged retention head on the burner
Why not call them and see if they can do the service early? Make sure they actually clean and adjust the burner, clean the boiler and do a combustion test.
There is always the possibility that there was a leak when the technician worked on it in the past. If the oil found its way inside the burner motor, there is no way to wipe it dry without taking the motor housing apart. That is not done regularly. That oil will just sit there and eventually evaporate away leaving the red stain behind. That would eventually stop dripping.
If the leak is ongoing and shows no sign of stopping, then you have a leak in the pump seal or on the high pressure line, or nozzle after drip. For the oil to build up enough to get into the motor housing is not very common. I would call for service sooner that later if the leak is ongoing. If the leak has stopped, then it can wait.
Our oil burner is the same in the picture. I found a slow drip that seems to be coming from the seam on the white part that has the model number sticker on it. Our burner tech has taken it apart several times and doesn’t seem to know how to stop the leak. Should I get a second opinion from a different oil burner tech? Also, is this dangerous. Does it need immediate attention?
I would also check burner pitch. If burner is not level or pitched forward, the after drip could be rolling back down the blast tube into the fan housing.
- 167 Indoor-Air Quality
