Ignition module without sensor tab on unit with two wire intermittent pilot.
EdwardP
Member Posts: 1
in Gas Heating
I am attempting to get a Modine PAE500 furnace functioning which has a UT intermittent pilot module, It has a UT 1003-600A intermittent pilot control module. My question is that the pilot has 2 wires, the sensor wire and the ignitor wire, but the electronic module has the SPARK tab but there is no connector tab for the sensor wire.
Where does the sensor wire attach?
A response would be greatly appreciated.
How is the current one wired?
Consulting0 -
May not be the original ignition module, seems Modine did it both ways depending on the model. Some modules sense the flame through the Ignitor circuit.
One Pipe System0
