Piping
jc2lite1
Member Posts: 18
The 2 vertical pipes are supply lines hooked up to the main return line. Also the 2- 3/4 to 1" return lines up on the ceiling are return lines as well from the radiators that run to a trap. Is this correct?
Weil McLain EG-50-PI 175000 2 pipe Steam Boiler Vacuum System. Installed 12/13/91..
Can't see enough to tell but probably OK
"Is it correct?" How are things running?
Seems to be running ok. The pipe on the left is 1 loop and the right another loop, so I guess it is correct. End of loops dumping to the return?
- 15.8K Strictly Steam
