Piping
The 2 vertical pipes are supply lines hooked up to the main return line. Also the 2- 3/4 to 1" return lines up on the ceiling are return lines as well from the radiators that run to a trap. Is this correct?
Weil McLain EG-50-PI 175000 2 pipe Steam Boiler Vacuum System. Installed 12/13/91..
    EBEBRATT-Ed Member Posts: 20,711
    Can't see enough to tell but probably OK
  • Intplm.
    Intplm. Member Posts: 3,112
    "Is it correct?" How are things running?
  • jc2lite1
    jc2lite1 Member Posts: 18
    Seems to be running ok. The pipe on the left is 1 loop and the right another loop, so I guess it is correct. End of loops dumping to the return?
