is my home boiler Honeywell RA832A relay bad?
2»
    Jamie Hall Member Posts: 27,313
    Let me add. If the device has power, did you try jumping from T to T? And if you did, what happened?
    EdTheHeaterMan Member Posts: 12,127
    WOW… @Jamie Hall another guy may have been SHOCKED as a result of this post. I hope he gets GROUNDED and finds a way to ZAP back to work on this ELECTRIFIED issue.
