Ice cold fuel - like bad as I’ve ever seen - pics attached
so, some of you may have seen other posts where I have dealt with cold fuel oil in several diff creative ways. Depending on the circumstance. This one really takes the cake. Why they went with two pipe is beyond me - tank is above ground, about 10’ away, outdoors. Two pipe is def not needed. But man to me this is Awsome 😂😂😂
I mean HECK yea - other great news is guys they been having service it says “you never work on them or tune them when it’s winter and risk it going down cause you touched it and it’s 20 below zero out” so he comes mid summer and tunes and sets it up, so that’s great let’s tune it when the fuel is 70 degrees hitting the nozzle and air intake / more humid / etc… then surely it’ll run fine when the fuel hits it at -25 or -30 and the air is so dry face shrivels in 10 minutes outdoors etc - lol
Heck yea - I love this plan - I mean I never seen a line that cold and I’ve seen some cold ones, I’ve seen them frosted for some distance but never the entire filter looking like it’s a fake made of snow one. 😂😂😳😳😳😳
tiger loop here we come, with 1 gallon inline resivor for additional pre-heated fuel. Great old unit though.
I will make a bet that you have less than 1/3 tank of fuel.
What you are observing is the fuel making the round trip and getting warmer each time it does that. The warmer fuel warms the line and you are observing condensation (in the form of frost) on the exterior of the line.
It's not the extreme cold you are observing………..it's simply an uninsulated two pipe system. I happen to like the two pipe system in the cold. Less need to treat the fuel. More velocity to prevent gelling. Of course, you can get additional benefit by insulating the lines.
Going to one pipe and a tiger loop is a waste of money. It may perform worse than the setup you have now. Just spend a few pennies on insulation.
central alaska
Just shows you what -41° can do. Is the tank frosted over yet??? If the boiler can warm the oil sufficiently………….that could occur…………..but probably not with 275 gallons. That's why I figured it was 1/3 full.
I would assume you must add treatment regularly to prevent it from gelling? Or do you use a different fuel than #2?
Is there a reason why the oil tank is not inside. i'm not much of an oil guy and I really ain't too familiar with having outdoors tanks at that temperature so I only ask out of ignorance. We in Boston don't get down to those temperatures.
i would think that having outdoor temperatures in the ranges your describing would require indoor tanks. but what do I know lol.
I used to recommend to people with outdoor tanks to install a heavily insulated storage cover using 2" minimum Styrofoam and a 60 watt incandescent bulb or 2. When the temp falls too low, turn on the light. You could also add a low temp temperature controller. Maybe this is something you could consider doing.
treatment.
believe it or not indoor tanks are extremely rare here. Honestly I don’t know why - but it’s just not a thing. All outdoors. For many years all buried. I still run on a buried tank at my home. If I sell I will have to replace with above ground to pass inspection. I think the transition happened and that’s when everyone went above ground outdoor. As long as you run a two pipe it seems to work fine but you know fuel that cold is inefficient as heck. We can make it run good on it - you can adjust to about anything but it’s still very inefficient. Also you know it’s not running optimal when we warm back up but are still cold enough to need heat. Like 20 above or 30 above zero. But you don’t get called back to adjust. 🤷🏼♂️🤷🏼♂️🤷🏼♂️1 -
I think it’s just what we all do - indoor tanks are so rare here I actually don’t think I’ve seen one. Lot of buried tanks. It is odd to never see an indoor tank here. My home tank is buried - was there when I bought it. Was a 2 pipe - I switched to tiger loop.
I've seen pics of some outdoor tanks with 2 inch off the bottom until it gets indoors. Then reduce to whatever.
- 116 Geothermal
- 52 Industry Classes
