One or two zone setup
dermy22
dermy22 Member Posts: 8
Recently bought a house with a configuration as follows:
  1. Trane heat pump > 40°
  2. Buderus furnace < 40° powers baseboards
  3. Radiant heated floors
Currently, my Buderus is set to one zone. Does that make sense? I feel as if we have baseboards and radiant heated floors it doesn’t sense to have everything on one zone. Happy to add pictures of the pumps to see if it would make sense to separate them into two zones (one for baseboards and one for radiant floors).
  • GroundUp
    GroundUp Member Posts: 2,483
    Is it heating like it's supposed to or do you want more control? There is really no reason to have multiple zones if everything is set up/ balanced properly and the temps are where they're supposed to be.
    pecmsg Member Posts: 6,900
    Baseboards and Radiant in the same room(s)
    hot_rod Member Posts: 27,095
    If these are different rooms or areas of the home, control over the two zones may be helpful. You need thermostats in the two locations, of course.
