Missing main vents
I have 1 pipe steam system (house built 1920) and have been learning more about it. I’ve been looking for my main vents and I don’t see them. All of the main piping is exposed in the basement. I just replaced all of the vents on the radiators but worried that without the main vents I’m going to have issues ? This is the only place where it looks like there might have been a vent? There are 2 main pipes that split to either side of the house, and I couldn’t see anything at all on there side.
so should I get main vents ? And how should I go about it ?
look for where the end of the mains turn down to the floor. They should have put a reducing tee there for the main vent to fit into.
Not if it was originally coal @ethicalpaul. There is an 1/8” plug in the picture. That could be removed and venting added. It’s certainly not ideal as it looks like it’s on a slight angle. Theres also a concentric reducer on the horizontal…where are you located @jlc229 ?
true enough @Danny Scully but mine was originally coal and had a plugged tee at the end of the main.
Of course I don’t know who or when that was added, but someone at some point was thinking “a vent should go here”
See my sight glass boiler videos: https://bit.ly/3sZW1el0
- 123 Chimneys & Flues
