Warm morning blower not shutting down
Hello. I have a warm morning (VR85EMAB) propane heater. The blower stays on until it blows cold air. When it re-lights, there is a big whoosh sound. What is wrong with my blower motor?
    pecmsg Member Posts: 7,000
    it’s shutting down on a safety.
    call your service provider.
    kimberlee
    EdTheHeaterMan Member Posts: 11,963
    edited December 2024
    This is a vented space heater, Correct? It sounds like there may a part needed, that operates the fan. also the Whoosh tells me that you need maintenance.
    Since The company that makes Warm Morning is no longer in business, you will need a professional that is familiar with older equipment. Some kid just out of trade school won't know what to do with it. The part needed for the fan to shut off earlier will need to be matched up at a supply house that has a knowledgeable counter man that can match up parts, not some new kid that only knows how to look up parts by the model and serial number of the brand of heaters they sell.
    Good luck finding that guy.
    kimberlee
  • pedmec
    pedmec Member Posts: 1,301
    That whoosh is delayed ignition. Very bad. call a local tech
