Steam boiler water
I have a 10 year old WeilMclain steam LbG 6/23 about 600,000 btu boiler in Chicago . Water is not real hard no softener is needed to shower . Should I filter or treat water ? Weil Mc Lain said no to adding chemicals. I have two tankless Takagi ng tankless that I use their Delime filter , I believe it’s a mineral that alkalines water . I do flush boiler off brown water every few days so a flush clean is never much of a deal . Is any treatment Going to help boiler life ? Or anything?
I don’t think you need a filter but stop your weekly draining. Did WM suggest that too?
Draining requires refilling, and refilling causes brown water, which is rust, so you are hastening the death of your boiler.
To prolong the life of your boiler I would normally say that the ph of your water should be increased to 10 or so. That dramatically reduces corrosion, see my short video here
But WM is a special case because for some reason (possibly due to their use of elastomer gaskets in their boilers) they advise a maximum ph of 8.5
How they think anyone can accurately measure .5 of a ph is beyond me.
I suspect that their ph warning is bunk but that’s for every individual to decide.
Your best off not adding fresh water to the system . Spend your time and money on fixing the leaks . Brown water tells me you have steam leaks … In theory and with a perfect system you only have to fill the system once .. I never seen one yet ,but you can get it down to a few gallons a year .
draining is bad ? I only drain maybe 1-3 gallons . Yes if files , auto fill about every cycle maybe 5 seconds. Fix steam leaks ? Like air vents ? I have 50 radiators, I thought this was normal ! How does removing - mud 1-3 gallons a day or week and auto fill ruin a boiler ? How does do I find Leaks? If the leak is only really noticed at the building pressure of a cycle . That means being in each apartment at that one point in a cycle ? Correct ? That’s difficult to just walk into a tenants apartment when the cycle starts . It’s like something that could take a month of bs. Not fun. My installer , well respected Chicago boiler co said draining like this was good it kept boiler clean. It is clean . The yearly flush gets almost nothing . Weekly every two weeks draining maybe 3-5 gallons it’s black , then it settles and builds. It’s a 90 year old place . Gorton vents , all different numbers .
ok. Vents can not close . We repacked radiator valves years ago . water under valve ok. What else to look for ? . Why is draining 2 gallon a day bad ? Why is new water bad ?
New water has dissolved oxygen in it. That dissolved oxygen is rusting your boiler. That's why you want to minimize makeup water as much as possible.
What you're doing is draining off deoxygenated water and adding new oxygenated water.
Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.2 -
draining is bad ?
yes
Don't do that
Normal does not mean good. Leaks are bad.
That mud is your boiler rusting away
The easiest way is to check them during a long call for heat where the radiators are completely full of steam and the vent should be shut. If it's letting out steam or water, you have to replace it. If the valves are dripping, you have to fix or replace them.
He's not respected by me. His advice is rotting your boiler out. Good for him maybe, not good for you.
I don't know what you mean by this
Oxygen boils off ! I’ve been told in a few minutes ! Pipes rust ! I don’t agree I’m killing the boiler with 50 radiators . The Kewanee was 50+ no leaks , black water for 5 seconds , the same . Repacking valves helped a lot . I take out hissing vents . I look for leaks at valve area , no pipe leaks . I’ll call Weil Mc Lain. I don’t believe I’m killing my boiler . Merry Christmas 🎉🍺🍺🥃🥃🍷🍷🧑🏻🎄🧑🏻🎄🎉🥃
Sorry but you are very much hastening the failure of your boiler when you keep adding fresh water full of dissolved oxygen. This is a well known established fact that any intelligent individual in the heating trades has known for a very long time.
Whatever you do, please don't move forward with your ill advised spray foam idea until you find and repair the leaks in your system. You will be kicking yourself later when the boiler fails and the source of leakage was never found.
Merry Christmas and good luck with everything.
2 -
Maybe its a good idea for the OP to read a few of Dan Holohan's books. Sadly, it seems OP always pushes back against good, sound advice in this thread ( and another one on foam ) P.S. Lay off whatever it is that clouds one's judgment on obvious expert opinions with good intentions trying to help
LINK to books:
Amazon.com : dan holohan books
Regards,
RTW
3 -
Oh really. RTW, Supertech, ethical paul, delcrossv. I spoke to Weil McLain tech Nathan, he was a long time installer and repaired boilers before joining Weil McLain. He said what I am doing is -JUST FINE-! As I said I remove just till brown water is out, maybe 2-5 seconds. Then boiler runs. oxygen in water boils right out fast. I will instal a meter to monitor water intake and not worry if its a gallon a week. He referred me to Sentinel Products for the proper Water treatments they endorse- recommend. I told him my maintenance procedures, he helped me a lot with Weil McLain recommendations. Bringing fear into this where I'm told I'm ruining my boiler etc should be reconsidered.
Then i guess you have all the information you need from Nathan. Good luck!
I wish Nathan would tell me why they say to limit pH to 9.5 when many other manufacturers say 11 is the max.
We're landlords too. Our buildings are 100 years old. Our boiler doesn't add water on each cycle. If your radiator valves have been checked anytime after Nixon was president, and you have Gorton vents that are newer than your radiators, they are probably much better than most. So where are you losing that much water?
As folks here are honestly trying to tell you, added fresh water causes corrosion and should be minimized. No reason to blow down a boiler every day. That's silly. Get a hobby.Seriously now, check for leaks. Do you have any buried (90-year-old) returns? Look for wet floors around the buried pipe. If all the pipe's visible and you don't see any leaks, and the boiler's not leaking above the water line and your domestic water stuff is fine you've done what you can for now.
yea beached ed , I guess I should say I runs about 2 seconds and your right Weilmc Lain tech doesn’t know what you know ! You’re the Pro! The Weil Mc lain Pro Technician , He said it’s ok ! A water meter is going in on the water feed line . I will measure gallons used weekly . The Nixon age insult or any insult is not appropriate in any discussion group . Happy new year 🎊🎈 🎉
@leaking, forum members with a ton of expertise in steam heating are taking the time to help you. You do not have to take their advice, but you do have to be respectful here. It seems like you are spending more time (on this and other threads) telling people that they are wrong and picking fights than on productive and respectful discussion that will solve your problem. You're getting in your own way. And if you can't follow our site rules, then you can't be here.
Forum Moderator
3 -
