Type of fixture ?
I’d guess delta or moen but hard to tell. You’ll have to remove cartridge to see what you need.
Steps to remove:
- Shut off water
- Pop the plastic trim off the control handle
- Remove center screw and control knob
- From there you should be able to remove face plate to access valve body and cartridge.
This video walks through the process nicely.
https://youtu.be/b7Z2KsD706M?si=vgUO9udMbe79ekhv1 -
Will OP require a puller to extract cartridge?
After you turn the water in the basement off….with the knob off and sliding off the chrome plated tube, you must be sure to remove the hair pin…horse shoe shaped clip from the valve.
That white nylon tool usually comes with the new cartridge. Rotate the cartridge around and back and forth. You can put a screwdriver shaft thru the hole in the cartridge shaft to pull as you rotate.
I then take a 3/4" copper fitting brush to clean out the body.
Then flush it by turning on the water for a few seconds.
I have someone hold something like a vac cleaner hose over the body to avoid a mess and get a longer flush.
Don't forget the hair pin clip.
2 -
- 120 Geothermal
