Testo 300
I just got a printer, but I can’t get it to work. The analyzer searches, but won’t connect. What’s the trick?
Did you get the right printer? I made the mistake of buying my Testo 300LL without the printer because I thought it would work with the printer from my Testo 320. I found that the 320 printer is not compatible with Testo 300. I believe the printer for the 300 connects by Bluetooth. With the Testo on I always turn the printer on and keep it around a foot away before I try to print anything. I don't remember doing anything special to connect it to the analyzer the first time I used it. Just make sure the Bluetooth is active on your Testo 300.
I just bought a 300 myself. Have not tried the printer but the printer does have to face the analyzer from the correct end. Setting up bluetooth and e-mail is impossible. Need to find a teenager to help me.
i would have attached a video but cant. green light on printer toward analyzer, turn on printer, tap upload icon on analyzer, print values.
- 121 Chimneys & Flues
- 15.8K Strictly Steam
