How to manually check pressure on hot water boiler
I have a Weil McLain hot water boiler system. I'm curious if there is a way to double check the pressure to ensure the gauge attached to the boiler is functioning properly. Is there a simple device I can purchase to manually check the pressure so I can compare that reading to the one on the machine? Thanks.
Here's one already made up.
https://www.amazon.com/Pressure-Female-Thread-Indoors-Outdoors/dp/B0CQT3F247/ref=mp_s_a_1_1?crid=280E5IA9509H0&dib=eyJ2IjoiMSJ9.rF6r4MdWKSI1A5hpQ2Be0zUOnC9uuevd0T5ckelv11nN_2evMivBnOJSVWB6eKfQkEmQrytDNr04tsXr07t3vZG2jlxr8s7h33wd4PVTs2ALrx6LAOXLaRS-Hv3abU7nQq4o91z8d59NolgFVQHuNDnYe5h05_nYGzYU_Na1eJkk8vH_Fr9SZObqRzE4nFXEIMyWEMsE_5roJsXcm0_GJA.FLwHKSaF2GiS2F_RO8ruKfGSwzNqQTZDXtM73KTY4p4&dib_tag=se&keywords=garden+hose+pressure+gauge+30+psi&qid=1734922138&sprefix=garden+hose+pressure+gauge+30+psi%2Caps%2C158&sr=8-1
Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.1
