Combi exhaust vent yellowing
Hi. My combi boiler exhaust vent is beginning to develop yellowish orange streaks on the seams of the vent pipes. Attaining a proper pitch is impossible in my home due to layout etc. Would a 90 degree elbow help with the ventilation? Thank you all!
Definitely the proper coupling - the inner seal looked fine. I'm thinking turbulent zone in that area and some of the exhaust is condensing onto inner ridges inside that portion in photo, and leaking downward. Just unsure how to solve - thinking introducing elbow with non corrugulaed inside
Lol sheet rock - it was like that when I started doing my thing
Is this the flexible Centrotherm venting system?
Yes - duravent from supplyhouse
I'll change it to a 45 degree and gradually work towards a gentler curve. The installation area is impossible to get the proper pitch to drain back to the boiler. Thanks for looking out
That won't help if it eventually runs horizontal , because that would be greater than 45 degree angle. Only vertical runs with the flex, its meant to drop down a chimney, they adapt to hard pipe before any bends. The 45 degree allowance is just to allow some maneuvering down a chimney, if you do a 45 degree, followed by another thats still a 90 degree angle.
1
- 123 Chimneys & Flues
