Combi exhaust vent yellowing
Robbi
Robbi Member Posts: 33
Hi. My combi boiler exhaust vent is beginning to develop yellowish orange streaks on the seams of the vent pipes. Attaining a proper pitch is impossible in my home due to layout etc. Would a 90 degree elbow help with the ventilation? Thank you all!
    hot_rod Member Posts: 27,848
    Probably leaking at that transition coupling? If that is the proper coupling there must be a seal inside?
    Nice sheetrock access :)
  • Robbi
    Definitely the proper coupling - the inner seal looked fine. I'm thinking turbulent zone in that area and some of the exhaust is condensing onto inner ridges inside that portion in photo, and leaking downward. Just unsure how to solve - thinking introducing elbow with non corrugulaed inside
    Lol sheet rock - it was like that when I started doing my thing
  • Derheatmeister
    Derheatmeister Member Posts: 1,659
    Is this the flexible Centrotherm venting system?
  • pedmec
    pedmec Member Posts: 1,460
    That yellowing is probably the lubricate changing color. Could be from heat, absorbing moisture, or aging
    GroundUp
  • GGross
    GGross Member Posts: 1,973
    When used for a flue the flex is not supposed to run at greater than a 45 degree angle ever. that's probably not what is causing the yellow, but somewhere in there you are probably trapping condensate as it can't run back to the boiler at that angle and will get trapped in the pipe
    Derheatmeister
  • Robbi
    I'll change it to a 45 degree and gradually work towards a gentler curve. The installation area is impossible to get the proper pitch to drain back to the boiler. Thanks for looking out
  • GGross
    That won't help if it eventually runs horizontal , because that would be greater than 45 degree angle. Only vertical runs with the flex, its meant to drop down a chimney, they adapt to hard pipe before any bends. The 45 degree allowance is just to allow some maneuvering down a chimney, if you do a 45 degree, followed by another thats still a 90 degree angle.
    Derheatmeister
