Amana PTAC control board compatibility
ptkeam
Member Posts: 1
Hi,
I have an Amana PTAC unit with a control board # PCBCP 146. I have tested and control board is bad.
I have seen used control boards with different #'s but appear to have the same configuration for the wiring. Is there a source for learning which board #'s are compatible?? I've posted a photo of the board I need.
Thanks
Peter
the Manufacturer.
