2 Pipe Steam Radiator / Blower Unit
Good Morning… I have a quick question… does anyone have any experience with this type of steam radiator unit? This is installed in what was a Chinese Grocery store here in Silver City, New Mexico (1937-1987 store was operating). I am the 'new' owner and am looking for information about the viability of this unit. It has an electric fan in the back. The unit is not currently working (but does not leak)… Ultimately I am looking to relocate this into my un-heated shop. Steam pipes are easy to access and the install should be relatively straight forward… I Hope…. Anyone out there have any ideas… is this a bad idea? is there a modern version of this that may save a rebuild? Any information is helpful. Thank you!
There should be a union somewhere to you can remove it. If the motor works, shouldn't be an issue reusing it.
Just make sure it stays oiled.
you'll want to replicate the sludge trap and screen like it has now in your new install.
Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.1 -
Why does this have a screen and mud trap but radiators don't?
A friend of mine has several boxes like this in his house, they brought in fresh air, ran it through the box and into the home, but they are all disabled now. One of them were even co-opted by air conditioner installers who used it as part of an ad-hoc air handler.
Probably due to the small passages in the heater.
I could see that perhaps if the screen were on the input, but that's the output, no?
I'd have to see it to be sure, but you may be right. Makes for a mystery.
Is that rotary switch to turn it on and off?
Great Information! Thank you all.
- 87.2K THE MAIN WALL
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 75 Pipe Deterioration
- 6.4K Radiant Heating
- 15.6K Strictly Steam
