Reddy Heater issue
Dgh2703
Dgh2703 Member Posts: 3
Hello all! I have a model R 100A heater. Had issue firing off. Did complete tune up. Filters ,air rotor and segments. New nozzle, new ignitor. Set air pressure at 4 lbs as called for . Replaced fuel with fresh. problem is - the unit fires right off and runs fine until I go to put cover on. Then sputters and miss fires. Pull cover off and fine? Any help is appreciated!
Thanks
    Jamie Hall Member Posts: 27,060
    Are all your air filters really clean?
  • Dgh2703
    All filters are new
  • GGross
    GGross Member Posts: 1,797
    Does it have a photocell in it that is maybe getting blocked for whatever reason by the cover when you put it on?
  • Dgh2703
    I bypassed the photocell to eliminate the possibility.
    thanks
