Brand New Taco Backflow Preventer leaking through center port
I installed this LF007M3-QT 3/4 to feed my new boiler. It is leaking a steady drip through the center port. Is it defective? Or have I done something to make it cry?
you have a piece of dirt solder, teflon , something stuck inside
Water enters from the left side the pressure pushes an inner spool against a washer or o ring see the t shape cut away of an o ring? The end of the brass spool contacts that
This closes off the bottom port , If water drips right away, something is lodged in that seal.
They are fairly easy to disassemble and clean out
Should be a strainer on the inlet? That generally catches most any problems?
This is a Caleffi, but they are all similar inside
Living the hydronic dream1 -
I bet you're correct about the solder. Thanks @hot_rod
is that a Watts? Always willing to help, but I don’t have any experience with that Valve
Joe Mattiello
Taco Comfort Solutions0 -
Thanks, @Joe Mattiello. @hot_rod was correct. I got it solved. Much appreciated.
