HOT WATER BASEBOARDS, Stumped
stagerock
stagerock Member Posts: 4
edited December 2024 in Oil Heating
Some info…. The return on the 2nd floor is always warm even when heat is off, the return on the 1st floor is cold when heat is off. (1st floor is in or under a slab) The interesting part is that every once in a while the heat on the 2nd floor skyrockets to 80 degrees even when the thermostat is off. I have only noticed this when it gets warmer outside. This has happened 3 or 4 times in 2 months. Other than that, this 12 year old system has worked perfectly with no issues. Any thoughts?
