Brand New Taco Backflow Preventer leaking through center port
I installed this LF007M3-QT 3/4 to feed my new boiler. It is leaking a steady drip through the center port. Is it defective? Or have I done something to make it cry?
    hot_rod Member Posts: 27,452
    you have a piece of dirt solder, teflon , something stuck inside
    Water enters from the left side the pressure pushes an inner spool against a washer or o ring see the t shape cut away of an o ring? The end of the brass spool contacts that
    This closes off the bottom port , If water drips right away, something is lodged in that seal.
    They are fairly easy to disassemble and clean out
    Should be a strainer on the inlet? That generally catches most any problems?
    This is a Caleffi, but they are all similar inside
  • Seasoned_Amateur
    Seasoned_Amateur Member Posts: 47
    I bet you're correct about the solder. Thanks @hot_rod
  • Joe Mattiello
    Joe Mattiello Member Posts: 751
    is that a Watts? Always willing to help, but I don’t have any experience with that Valve
    Joe Mattiello
    Taco Comfort Solutions
  • Seasoned_Amateur
    Thanks, @Joe Mattiello. @hot_rod was correct. I got it solved. Much appreciated.
  • Joe Mattiello
    hot Rod is brilliant!!
    Joe Mattiello
    Seasoned_Amateur
    even a blind squirrel gets a nut, now and then 🤓
    SteveSan
