I need a small Weil-McLain part if you’ve got one
Hello all,
How annoying is this? I need the P-11 plug-in terminal block for a WM U-Control on an Ultra 155. I’m wondering if someone has one laying around or can suggest an alternative way to make an equally good wiring connection to my DHW landing point.
Thanks in advance!
Johnny Cataneo
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes
Well, that sucks.
Sometimes you can cut a longer terminal block down to the five terminals you need. So if you have something longer? You "might" be able use that.
Or you can combine two smaller ones? I wish I could be more definite in my response. It is a matter of trial and error for sure and worth a try if you cant get exactly what you need.
This one might work.
https://www.digikey.com/en/products/detail/on-shore-technology-inc/OSTTJ055153/1588596
Owner of Grunaire Climate Solutions. Check us out under the locate a contractor section. Located in Detroit area.
2 -
@offdutytech is right, the name to Google is Phoenix. It's a brand name, but like "Kleenex" it'll get you what you want. You can check mouser.com or digikey.com too, if Amazon isn't your thing.
We had a local electronics shop where I went to match connectors like that, but they had to move when their rent doubled. Gotta love gentrification.
thanks, guys. I’ll see what Phoenix has for me.
Classes0 -
you can buy those from electronics suppliers. it is a phoenix connector. someone like mouser or digigkey will have it. there are different sizes and configurations so you will have to measure it and match it up.
- 121 Chimneys & Flues
- 15.8K Strictly Steam
