Home heating boiler
Cdcox
Cdcox Member Posts: 19
pros and cons of leaving the inlet valve turned off
  • jesmed1
    jesmed1 Member Posts: 1,474
    edited December 2024
    I assume you're asking the pros and cons of leaving the makeup water inlet valve closed. That has been discussed here often. You'll find pros and cons in this earlier thread:
    https://forum.heatinghelp.com/discussion/comment/1811311#Comment_1811311?utm_source=community-search&utm_medium=organic-search&utm_term=makeup+water+valve
    Cdcox
  • GroundUp
    GroundUp Member Posts: 2,513
    What?
