Home heating boiler
Cdcox
Member Posts: 19
pros and cons of leaving the inlet valve turned off
I assume you're asking the pros and cons of leaving the makeup water inlet valve closed. That has been discussed here often. You'll find pros and cons in this earlier thread:
https://forum.heatinghelp.com/discussion/comment/1811311#Comment_1811311?utm_source=community-search&utm_medium=organic-search&utm_term=makeup+water+valve
1 -
What?
- 125 Chimneys & Flues
