Treasures!
I have sears dunlop banded one like that. I suspect someone could re-grind the teeth. I wonder how they were cut in the factor. Probably with a mill.
My Dad had one of those. I think my brother still has it.
yeah i thought of that, but leveling them first would do better and that would be a lot to do with a file. Is there a foley bellsaw pipe wrench jaw sharpener?
On 2' Ridgid I use a 1 1/2" piece of electrical EMT. You hammer 1 end of it oval to fit over the Ridgid handle. When you push it on it locks to the wrench handle and comes off with a hammer tap easily. The EMT is a lot lighter than pipe and is easier to handle when you're on a ladder struggling with a wrench and cheater. And the EMT is very difficult to bend.
I used to make one out of 2" emt and 1 out of 1 1/2" emt 2' long and store 1 inside the other in the truck.
I get a bit of nostalgia and like to use my Great Grandfather’s pliers, post WWII, mfg in the British zone of occupied Germany.
Hi @akjim , Interesting you show those pliers. I was just using these today. 😊 Yours don't look so abused. 😏
Yours, Larry
Why are there waffle head hammer marks on them?
Lineman pliers are often used to apply hammering to the nail for wall boxes when there is only maybe 3" between studs.
Pliers against the nail and hammer on the center of the pliers.
I have plenty of pliers that have been abused as such.
But do not hammer on the pivot side of the rivet or it may jam up the pivot action……I have a few of them also.
Note: as for the paint….shows the durability of lead paint….don't chew on them.
Hi @mattmia2 , I promise you I got them that way. It's not my style to do stuff like that to my tools. One jaw is a bit crooked, so you know these pliers got wailed on 🙈
Yours, Larry
1
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 113 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
