The case of the upside down control panel, this Friday's case
RayWohlfarth
RayWohlfarth Member Posts: 1,978
In this weeks case, we inherited a building with lots of issues. Let's start with the heating. The system had 5 zone circulators with 5 wireless zone thermostats. It was an incredible complex control system for a relatively simple heating system. When we arrived Thursday afternoon, one thermostat wasnt communicating with the panel in the basement. We temporarily bypassed the zone control panel and wired the pump to run continuously. The weather forecast called for temps in the teens. Friday, more thermostats failed to communicate. The customer told us the system hadn't worked since it was installed. What would you do? I'll give you my solution Friday at 6am
Ray Wohlfarth
Boiler Lessons
  • ratio
    ratio Member Posts: 4,229
    Constant circulation with reset?
    Sometimes, controls are too far gone to find & fix a failure, & ya gotta just start over with a blank slate.
    Intplm.RPK
    109A_5 Member Posts: 3,959
    Upside down control panel, who would expect that to work the electrons and RF will fall out.
    GGross
  • RayWohlfarth
    edited December 2024
    @ratio That's what we did
    @109A_5 LOL
    Ray Wohlfarth
    Boiler Lessons
