Simple Control For Hydronic Coil Discharge Temperature
Paul_4
Member Posts: 9
I have an outdoor air intake with a hydronic heating coil in the air stream. I have a variable hot water supply temperature entering the coil. I am looking for a simple control solution that can modulate a control valve based on the discharge air temp off the coil. The temp would be set for ~70*F.
This can be self actuating or using electro-mechanical means. Thanks in advance!
I'm thinking along those lines. Presumably when you say "modulate" you don't mean turn on and off but turn to intermediate values.
Is the valve there already? Or does the solution have to include a valve?
Thank you all. I also found the Honeywell T775 controller which seems to be able to modulate a valve to control a discharge air temperature.
- 50 Industry Classes
