Where is this leak likely coming from?
I’ve been losing water recently with no findings at the main vents, radiator vents and valves, which lead me to the boiler. I flooded the boiler and about an hour later i saw water dripping onto the burners and coming out through the front. I took off the top of the jacket and found the block to be wet, is it possible to tell me where it’s likely coming from? The sides look and feel dry.
