Old radiator bleeder valve
Jeremey981
Member Posts: 2
Hi old radiator here...how do you bleed a valve like this? It looks like there is a hole at the end but there isn't a hole there...
That is a manual bleeder for hot water heat and requires a radiator key, which is square and fits over the end. It should be available at a good hardware store. Turn it to the left and air/water will come out of the spout at the bottom.
Bburd0 -
You need what they used to refer to as a "skate key"
All of the valve stems that i saw that use a key have some sort of hole or indent for the key to go into with a square piece inside...this one doesn't have that..
It has the square part, it just doesn't have a rim around it. You could change it with a new valve if you are having issues with it.
