Old radiator bleeder valve
Hi old radiator here...how do you bleed a valve like this? It looks like there is a hole at the end but there isn't a hole there...
  • bburd
    bburd Member Posts: 1,324
    That is a manual bleeder for hot water heat and requires a radiator key, which is square and fits over the end. It should be available at a good hardware store. Turn it to the left and air/water will come out of the spout at the bottom.
    Bburd
    EBEBRATT-Ed Member Posts: 20,750
    You need what they used to refer to as a "skate key"
  • Jeremey981
    Jeremey981 Member Posts: 2
    All of the valve stems that i saw that use a key have some sort of hole or indent for the key to go into with a square piece inside...this one doesn't have that..
    mattmia2 Member Posts: 17,814
    It has the square part, it just doesn't have a rim around it. You could change it with a new valve if you are having issues with it.
