This weeks video, Why boilers are still great.
RayWohlfarth
RayWohlfarth Member Posts: 1,932
Due to consuming excess turkey yesterday, I am delayed posting this weeks video. Hope you enjoy it.
Ray Wohlfarth
Boiler Lessons
jesmed1
  • jesmed1
    jesmed1 Member Posts: 1,362
    Thanks for that video, Ray. We have two oil boilers heating our 4-unit condo building, with the original cast iron gravity-converted hot water system. We burn about 1200 gallons of oil per year, so that is a major expense. I've been looking at various options for reducing our heating costs, including heat pumps.
    As you say, heat pumps wouldn't last as long as our cast iron boilers, and then there are the mechanical problems associated with conversion. We'd need two large air-to-water heat pumps and a large buffer tank. I called a few local heating companies who do heat pump conversions, and their ballpark cost estimate was comparable to a mid-range Tesla. Which we as a small condo association cannot afford.
    So when the time comes to replace these boilers, we'll be installing boilers again. Probably basic cast iron ones, though I would love to be able to afford an Energy Kinetics.
  • RayWohlfarth
    @jesmed1 Thanks for the feedback. What if you looked at hybrid system with one condensing boiler and one standard. You would get the efficiency of the condensing system at a much lower costs. I think Peerless has condensing oil boilers.
    @Revenant You have some good points. I read on one of the government studies that gas powered utility plants are only slightly higher efficiency, 38 versus 32% I was just trying to show the lifetime costs of one system versus another. We are seeing rooftop units and heat pumps now failing after 10 years. I believe in using as little energy as possible. I guess that's from my father yelling whenever he found a light on or is we spent too much time looking in a refrigerator. Thanks
    Ray Wohlfarth
    Boiler Lessons
    jesmed1ethicalpaul
  • jesmed1
    @RayWohlfarth Thanks for that tip about the Peerless condensing oil boiler. I was not aware of those. That could be a good option for us.
  • RayWohlfarth
    @jesmed1 very welcomes
    Ray Wohlfarth
    Boiler Lessons
