Hudson reed valve
does anyone have any experience with these Hudson reed valves for rads. The compression side is 16Mm. Seems pretty loose on 1/2 copper pipe. Just wondering if anyone has any experience with these and If 1/2” copper will work. Thanks
Not a plumber but you should probably plug your phone in before it dies completely.
what type of fitting is it? Does it have o ring seals and a crimp ring?
I have been able to get 1/2 copper into a 15 mm fitting by sanding the tube od a bit.
For the U.S. market Caleffi has this 437 fitting. I don’t know if it matches your valve. Recently they standardized that conical thread, across all the brands.
it’s just a brass sleeve. Just seems loose on 1/2” copper.will look into the #437
a brass compression ferrule needs to be a snug fit or it may not bite into the tube. Not something you want to risk with water under pressure
