Adventures In Steam Heating
HeatingHelp
HeatingHelp Administrator Posts: 716
edited November 2024 in THE MAIN WALL
In this episode, Dan Holohan shares some basic principles of how steam heating systems operate and why opportunity knocks for those who work on them.
Read the full story here
  • ChrisG525
    ChrisG525 Member Posts: 1
    steam boiler two pipe system steam trap at the end of the main is not getting hot only 160° on the inlet hundred degrees on the outlet
    Condensate return using a vacuum-system. Vacuum tank running well and service the steam trap at the end of that run and still no heat on the risers. Please help
  • pedmec
    pedmec Member Posts: 1,238
    are you sure your pump is pulling a vacuum?
    Jamie Hall Member Posts: 26,716
    If the steam trap at the end of the main — a crossover trap, I presume, to a dry return? — isn't getting hot, steam isn't getting there. So… how far down the main does steam get? How is (are) the dry return(s) vented? Are they hooked up to the vacuum pump or atmospheric vented? Do they, or any part of them, get hot? And… where are your drips to the wet returns? Are they clear? No stray traps to double trap things?
    Really need a lot more description of this system.
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,370
    Outstanding Dano! Mad Dog
