Riello 40 FS10/GS10 gas burner not firing up in winter
hammerton
hammerton Member Posts: 1
edited November 2024 in THE MAIN WALL
Hi all,
I have a Riello 40 FS10/GS10 gas burner that heats our brewery boiler (essentially a big liquid tank) I had it serviced in May but when it gets colder and damper in the UK it seems to struggle to fire up at all and can take up to 30 minutes of restarting for it to finally fire up. I was hoping the service would stop the issue, but alas it has not.
It works fine in the summer its just the winter months when the issue happens.
Thank you in advance for your help.
    Jamie Hall Member Posts: 27,221
    "colder and damper"
    check all your connections, especially grounds, and the ignitor.
  • HeatingHelp.com
    HeatingHelp.com Member, Moderator, Administrator Posts: 223
    @hammerton, welcome to Heating Help! I've merged your duplicate posts into one here to prevent confusion. Thanks.
    Forum Moderator
