Strange air filter set up? 6 filters in one box?
Totally new to this space -forgive any ignorance .
I just bought a new house and I went to check the filters for the ac/furnace… There are six individual filters in a zigzag pattern
What ism I dealing with here? Just old?? I tried to research elsewhere, but I’ve come up empty so far.
house is 80+ years old.
Thank you!
Lennox LX 6H?
thank you for the response! Is there an advantage? Never seen this on any other system..
That filter arrangement is common on commercial size systems, for instance the makeup air unit in my 128 unit condo building. It's much less common in individual houses.
Bburd0 -
That system you have may be for a commercial installation that someone installed in your home. Those filters should be a 2" wide metal type filters made specifically for that unit and were electrically charged with a high voltage. They claimed that these units cleaned the air very well, but needed monthly cleaning. I never liked this type unit but that is my choice. There should also be a power unit included in the package. My guess is that the power unit went "bad" and the owner got rid of the electronic part and installed regular filters. Post a picture of the whole unit so we can see just what equipment is installed. That model Lennox furnace with the panel lock levers was fairly common when I got into the HVAC business in the late 60's
