Strange air filter set up? 6 filters in one box?
Totally new to this space -forgive any ignorance .
I just bought a new house and I went to check the filters for the ac/furnace… There are six individual filters in a zigzag pattern
What ism I dealing with here? Just old?? I tried to research elsewhere, but I’ve come up empty so far.
house is 80+ years old.
Thank you!
Lennox LX 6H?
    EBEBRATT-Ed Member Posts: 19,891
    The filters are installed in a zig zag pattern to get more surface area of filtration in a given air handler (box size)
    thatoldhouse
  • thatoldhouse
    thatoldhouse Member Posts: 2
    thank you for the response! Is there an advantage? Never seen this on any other system..
  • bburd
    bburd Member Posts: 1,273
    That filter arrangement is common on commercial size systems, for instance the makeup air unit in my 128 unit condo building. It's much less common in individual houses.
    Bburd
  • retiredguy
    retiredguy Member Posts: 1,084
    edited November 2024
    That system you have may be for a commercial installation that someone installed in your home. Those filters should be a 2" wide metal type filters made specifically for that unit and were electrically charged with a high voltage. They claimed that these units cleaned the air very well, but needed monthly cleaning. I never liked this type unit but that is my choice. There should also be a power unit included in the package. My guess is that the power unit went "bad" and the owner got rid of the electronic part and installed regular filters. Post a picture of the whole unit so we can see just what equipment is installed. That model Lennox furnace with the panel lock levers was fairly common when I got into the HVAC business in the late 60's
