What is this basement window vent about?
Not my house.
Clearing out old photos from some open houses I attended in 2024.
What is this for?
Is this is combustion make up air intake unit for boiler?
that’s a good guess
I’d say yes. Have you check to make sure other side isn’t obstructed?
YES.
Unless, of course, you have a new, modern, deluxe, special, first class, unique, model 4Q2- hyper turbulent, multi-radical, extra quiet, variable-monochrome channel, for a mixture of oxygen and nitrogen along with argon and other trace gasses from the atmosphere to migrate from an unconfined space into a confined space to the development and promotion of rapid hydrocarbon oxidation resulting in a pristine conversion of thermodynamic energy that ultimately result in the comfort of the owner os this device.
Most codes require both high and low openings for combustion air flow into a confined space without mechanical assistance. It looks like someone has closed off the high one, probably due to cold drafts.
Bburd0 -
How confined does the space need to be? Do most houses have this? This was the first I ever saw. It was in a standard 100 year old basement.
When do you need one of these? My house does not have one. My basement boiler has walls and a door built around it so it's technically in its own little room with some storage shelves. I don't think it's air tight.
@CoachBoilermaker I suggest you look up the combustion air provisions in the mechanical code that applies where you live. They vary by jurisdiction.
If your boiler is enclosed as you describe, there must be provisions for adequate air from elsewhere in the house or from outdoors to come in for combustion. If there aren't… this is how people get carbon monoxide poisoning.You have CO detectors, right?
Bburd0 -
Yes, just got a brand new one and put it right next to the boiler. Reading zero.
It's in the basement, which is not air tight. The boiler closet room is a makeshift room with drywall and a cheap closet door. It's I was keeping the boiler room door closed, to keep the boiler room hotter, to keep the tankless coil water warmer, to save fuel. Is that a mistake? and I can leave the door open if that's safer.
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
