Tube Heater wiring loop
Hi I'm no sparky but have learnt a little over the years, I have an issue with the heating layout in my aviary, I have 3x 80w tube heaters and 2x 40w tube heaters but only have 2 plug sockets, is it possible to loop all the tubes to 1 plug or will it trip out, could possibly run 2 plugs
Well, "loop" is not a term one would use — since it implies connecting them in series, which wouldn't work.
But. Can you plug the lot of them into one outlet? Yes. Your total power requirement is 320 watts, and a single 15 amp circuit can handle 1800 watts. So no problem there. The question is, how to do it safely? I would suggest using one of these:
Power Strips, Industrial Power Strips in Stock - ULINE
(there are several models in that listing). They can handle long duration loads without heating. Plug all your lamps into one, and then plug it into your existing plug.
