Stainless pump for DHW
ok was wondering, thanks
@Larry Weingarten knows his stuff. I'd follow his recommendation honesly.
these tankless water heater cleaning kits come with a citrus acid. I think this brand had a packet of powder to mix with the water. You can buy the acid for these seperatly.
I use it to descale thermostatic mix valves.
will it remove rust ? On plastic?
maybe. Depends if it stained into the pores of the plastic, I suppose.
I'm doing more reading about using Oxalic acid to clean filters and housings.
Seems like it's ok to use for that as long as you do it safely, gloves and glasses, people say it's really not bad.
And it's in Broccoli so how bad can it be…. lol
Im still researching it, also would like to know if it's safe for septic.0 -
right…0 -
Hi guys, starting to move forward again, putting together a parts list, I'm not finding the pressure relief valve I thought I was looking for.
This is for the heating loop side. Can anyone recommend a valve. I think I will have the loop pressurized at 15psi unless I learn otherwise.
thank you !0 -
User standard 30PSI boiler relief valve. Sometimes stock item at a local box store if you have a lot of hot water heating near you.
thanks , I was thinking that. At first I had it in my mind to find something like my well pressure tank has.
Then I realized that's not going to work.
Ok , just wanted confirmation on that.
I appreciate everyone's help here. I'll be back with more questions as I go along.
Still need to figure out what water to fill the system with. It was suggested I find out how hard my water is. I got a test kit but haven't used it yet, but will soon.Thank you sir..
Larry, what about using Reverse osmosis water, I make that all day long.. or mixing it with raw well water, I still have to check it's hardness btw
RO , DI deionized, DM demineralized, and distilled all give you the same result , almost pure H2O
Its “hungary” water and will immediately try to buffer back to neutral ph. It does this by pulling from metallic components in the piping. Check that low ph water a few days after it was put in a system to see the ph change
Better yet add a hydronic conditioner to the purified water to buffer it and add good inhibitors
Living the hydronic dream1 -
Water from Hungary?
Ok, I understand that, people are telling me otherwise, I believe you as that makes sense.
I'll get back to this when I check my raw well water. Maybe I can filter it well to get the sediment out and it will work.
But as usual when I get help I get many different opinions and that gets confusing.
I do appreciate everyone helping me as I am learning.
so you guys know…The supply side water is well water passed through three 1 micron string wound filters.
Then through a large carbon block filter, then the water softener and then another string wound filter and into the water heater.
My water heater is doing double duty for now so I'm stuck with that.
If I have to replace the heat exchanger every so often so be it.
As for the heat loop side I will do the best I can for that part of the system.
This is not a critical setup, its basement heat where I have not had heat for 12 years since I put the basement in.
lol……
Is a hardness test kit the same as PH ?
"Is a hardness test kit the same as PH ?" Hi @hunter29 , These are completely different things. Hardness is solids dissolved in the water that filtration will not remove. Imagine dissolved sugar or salt in water. A normal filter won't catch it as it isn't particulate matter… PH is a measure of how acidic or basic the water is. 🤓
Yours, Larry
Thanks Larry, thats what I thought.
I found an old test report from 30 years ago. It listed my water at 20 GPG. But that came from a salesman.. LOLTomorrow I'll do a test and see if that is still the case..
How about Lake Huron water… lol
That's Detroit city water..
Hi all, making progress again, just want opinions on this.
I have the hot water loop , water heater to heat exchanger, hot from the water heater is on the bottom run, the return back to the water heater is above that.
Is there any reason not to put the pump on the return line?
I figure cooler water on the pump would be beneficial..
Thanks
Thanks
- 116 Geothermal
