What is this?
Anyone recognize this? I have a customer working on a job trying to figure out its function
  • Mtncom12
    Mtncom12 Member Posts: 3
    I guess it's on a wood fired boiler system
  • GroundUp
    GroundUp Member Posts: 2,482
    A thermostatic valve, a warranty requirement on Central Boiler products (though occasionally used with others) to keep return temp above 150*, though they almost never work like they're supposed to. If the underground lines and circulator are sized properly to maintain a good return temp, it can be removed or possibly even gutted (there is an automotive type thermostat inside that can be removed) depending on the system.
  • Mtncom12
    That's awesome! Thanks so much for your help!!
