What is this?
Mtncom12
Member Posts: 3
Anyone recognize this? I have a customer working on a job trying to figure out its function
I guess it's on a wood fired boiler system
A thermostatic valve, a warranty requirement on Central Boiler products (though occasionally used with others) to keep return temp above 150*, though they almost never work like they're supposed to. If the underground lines and circulator are sized properly to maintain a good return temp, it can be removed or possibly even gutted (there is an automotive type thermostat inside that can be removed) depending on the system.
That's awesome! Thanks so much for your help!!
