Hydronic piping arrangement
bluesnake100
Member Posts: 5
Just for sanity check. I'm looking to add a zone with 2 cast iron radiators and 1 cast iron baseboard. This piping arrangement should work correct?
1/2" branch off to each heating element.
Thanks, Will make that correction, beside that, the setup should work correct?
Yep. Still might need some balancers, but yes.
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
