T1 vs T3 vs T6 In Floor Heat only
Looking at non-programmable thermostats for my in-floor heat only. I don't really see much difference in the T1 and T3. The T6 adds programing abilities that I don't need unless the algorithm it uses is better for hydronic heat. No in-floor/slab sensors.
If the algorithms for cycles per hour and heating are all the same I see no reason to go T6 and I should just pick the T1 or T3.
  • joshavan
    joshavan Member Posts: 7
    Leaning towards T1 in most areas like bedrooms bathrooms....
  • Ironman
    Ironman Member Posts: 7,886
    You should use the T6 HYDRONIC stat with no setback for radiant floors.
    Bob Boan
  • joshavan
    I don't have slab sensors would the t6 hydronic do any better than those without a slab sensor?
  • Ironman
    Yes, its algorithms are designed specifically for radiant floors.
    Bob Boan
  • GroundUp
    GroundUp Member Posts: 2,482
    Can you elaborate a little on this please? I have a T6 hydronic in my garage and a basic Pro1000 in the other garage, but can't tell any difference in performance. What sort of algorithm are you referring to?
  • joshavan
    edited November 2024
    The only thing I see that it has is the Adaptive Intelligent Recovery which would just be recovering from setbacks nothing that would help manage the heat at a consistent level, but I could be wrong.
    EdTheHeaterMan Member Posts: 11,752
    @Ironman That is an interesting comment. I remember going to Honeywell sponsered classes when Flame Rectification controls became popular in the 1970s. I didn't have a complete understanding at the tile but I remembered that the ground circuit from the flame back to the control was important and that the flame conducted electricity. But I could not explain the technical points about the current being rectified from an AC current to a DC current and all that goes into that.
    So I'm wondering if you have attended a class or seminar that explained the algorithm and why it is better for Hydronic systems. I believe that there could be something about how the thermostat reacts to overshooting temperatures and calling for heat to late if it were just a forced air thermostat set at 6 CPH. I was still attending seminars and even teaching seminars when Intelligent recovery was being added to Chronotherms. I also remember that one manufacturers representative commented the Honeywell missed the boat whey they introduced the Lyric by calling that feature Adaptive Intelligent Recovery. NEST just said it was a Smart Thermostat. Simple and to the point for the general public. Lyric came out first as I remember so they could have used "Smart Thermostat"
    There I go rambling again…. To sum up, I was wondering how you know the T6 is better than the T1 or T3.
  • Ironman
    I’m not by any means qualified to explain algorithms. That’s simply what I was told by my Honeywell rep. Ed probably explained it best.
    We’ve been using the T6 hydronic stat for about 5 years with no issues after switching from Tekmar’s 519 which we had problems with.
    Bob Boan
  • joshavan
    @EdTheHeaterMan So if I am understanding you correctly to the best of your knowledge, in my use case since I don't need a programable thermostat and I don't have floor sensor the T1 would operate no different?
    In my opinion, that is true. But A Honeywell Rep seems to think differently according to @Ironman. But They make more money on the higher priced thermostat. Sooo. there is that!!!
  • GroundUp
    Tekmar stats in general are garbage, IMO. Not to take away from the T6 because it is a great thermostat, but personally I have not found any temperate benefit to a T6 compared to any other Honeywell stat. Obviously the basic Pro1000 and such are cheaper and therefore a little less precise, but I've got hundreds of them out there without a complaint. I put the T6 in my garage simply to play with the floor sensor which I never use anymore, but it maintains an almost identical performance on air sensing mode to the T4 that preceded it.
