Hyrdostat 3250 Plus Temp Display Flickering
SunRad
Member Posts: 8
I just installed the Hyrdostat 3250 Plus to replace an old Aquastat on my Burnham 240k BTU hydronic boiler. I opted for wall mount since the space is tight on the side of the boiler and I wanted the ability to adjust the settings easily if needed.
I confirmed the unit is grounded by testing between L1 and GRD and it shows 120V on my multimeter. It's also using the Thermowell for LWCO functionality which is working correctly. The only issue is a slight flicker on the temp display. I'm wondering if this is normal or should I replace the unit? The flickering you see in the video is exactly how it appears in real life.
Thanks for your help!
Thank you @EdTheHeaterMan. Will do.
- 50 Industry Classes
