Gas w/heater bad component symptom?
We have an approx 20 year old gas heater that I've been maintaining since we bought the place 3 years ago (flush/fill and new anode rod).
Today it wouldn't fire up until I flipped the power off and on. Green led is steadily blinking bright-dim.
Seems to be working OK now but is this an indication of a component on it's way out? If so, which could be the culprits?
Or, am I overthinking this and they just need to be rebooted once in a while or should I be grabbing a new one?
Thanks
Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
Hi, It looks like a power vent unit. Things also look a bit dusty. I would start by checking/cleaning every electrical connection and see if it helps. Use contact cleaner in any switches. If there is no change, I see AO Smith's helpline to call. The tank looks nicely installed. I would do one more thing and add a line from the relief valve down to near the floor. 🤠
Yours, Larry
Thanks. That's what I was hoping. Will start with that, maybe even remove and clean/descale the thermostat
Hi, With a lot of water thru put and really hard water, I've seen the thermostat probe get buried in sediment. That really throws things off, but it's quite rare. 🦄
Yours, Larry
I haven't flushed the tank this year so I'll give it a good flush and clean as well
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
