Rebuild or replacement parts for 1929 vintage 1/2" Mouat Radiator steam trap
PD63
Member Posts: 2
My traps are not sealing. the disc that seals them close has worn. it is nolonger flat.
I would like to rebuild the traps (replace the internal disc) or replace the traps with one with identical dimentions and orientaton.
Tunstall or Barnes&Jones should have direct replacement innards for those.
Thank you I will take a look.
- 15.8K Strictly Steam
